WiFi versus Wireless LANs
olansgzsid
I've just started learning about Wireless networks and i have a question about the terms "Wifi" and "wirless Lan"
Whenever I think of WiFi, I think of connecting wirelessly to the network and to the internet, which is basically what a WLAN is, right?
Can these 2 terms be used interchangeably or is there any major difference between a WiFi and a Wireless LAN?
Hi @olansgzsidIn general, "WiFi" and "wireless LAN" refer to the same concept: the transmission of data over a wireless connection using radio waves. However, when "WiFi" is used more specifically, it refers to a specific protocol, such as WiFi 1 through 6, which involves the development of products that adhere to a set of agreed-upon standards. These products are designed to be compatible with the WiFi protocol and allow users to connect to the internet wirelessly.Jay0
Thanks for precious response... Appreciated your efforts...!!!Hi @olansgzsidIn general, "WiFi" and "wireless LAN" refer to the same concept: the transmission of data over a wireless connection using radio waves. However, when "WiFi" is used more specifically, it refers to a specific protocol, such as WiFi 1 through 6, which involves the development of products that adhere to a set of agreed-upon standards. These products are designed to be compatible with the WiFi protocol and allow users to connect to the internet wirelessly.Jay0
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
