I would like to use static ip addresses on WSQ60 Multy PLUS
fabrialare
I tried to use the reserve IP in the access list that generate a rule in setting lan
and i put some rule to in setting lan to force the devices to get a specific ip address
it works for a while but after a period non well understood the wsq60 cancel the rules and in the access list took off all the reserve ip
so i am back at the beggining
i would like to write the rule table for ever where is the mistake?
Hi @fabrialare
Please send us the feedback on the Multy APP.
To reserve IP, you'll need to enable to "Reserve IP" function on the Multy app
What do you mean you try to generate a rule in the setting lan, could you describe more details about it?
I have done what you suggestwhen you put that flag ( Reserve ip )if you access the mutly plus with local loginyou go at the option SETTING - LANyou will find the cahnce to manage the range for pooling the DHCPbut also the rules for the STATIC DHCP TABLEyou will find a rule in that table is the rule you activated with the reserved IPThe problem is after a while ( could be one day or some hours )You will find the table empty anf the flag reserve ip switch back offso you loose the rule and ip address will become free again not anymore static but dynamicthanks0
sorry for mistipyngis not CAHNCE but CHANCE the possibility to to manage ....0
Hi @fabrialare
Please help to export the log to us.
Or you can send us the feedback log on the Multy APP.
Hii exported the logi have got 3 files1 for internet2 for connection3 for otherbut how can i send it to youi do not see any kind of attachment icon for a tar fileIn any case i found outACCESS CONTROLif you unflag RESERVE IP in a device you will cancel the rule inSETTING LAN STATIC DHCP TABLEIf you flag it you write a rule in that tableIf you put dirctly a rule in STATIC DHCP TABLE and there is a device with the same mac address inACCESS CONTROL the ip address you put in the STATIC DHCP TABLE is irrelevantand you put the flag RESERVE IP on that device with the ip adddress you see in acccess control.So in reality you can put the ip address you choose in the rule but you are getting what the device got from DYNAMIC DHCP because you are reserving that oneIf you cancel the device in access control you will delete the STATIC DHCP TABLE not just your row but the entire table ( here i think is the mistake )So to put the ip address you want for a device since the table will be canceled you have to turn off the device, cancel the device row in ACCESS CONTROL go back toSETTING LAN STATIC DHCP TABLEinsert all your rule turn on back your device to have the right addressthan go back to acccess control and reactivate all the RESERVE IP ADDDRESS for all thos devices you want a precise IP ADDRESS if you are lucky non one is changedwell this is too much.Another thingSince i have got 4 WSQ601 Router 3 satellite ( or bridge or access point )i would like to have with ip addressesXXX.YYY.ZZZ.1 RouterXXX.YYY.ZZZ.2 SAT 1XXX.YYY.ZZZ.3 SAT 2XXX.YYY.ZZZ.4 SAT 3well if you put these rules in SETTING LAN STATIC DHCP TABLEand you restart all the WSQ60sthey will the right ip adddress for a while but yor STATIC DHCP TABLE will be deleted againSo it is very hard to use the STATIC DHCP TABLEIn this case you havent the FLAG RESERVE IP so it won't last ( here it is the other mistake )you do not see all the devices in acccess control, the others multy you see it in MY MULTYthe only sure thing you can do is to set the reserve ip in access controlbut that just block the situation in what the DYNAMIC DHCP has set for youor you have to make a big effort to select your IP ADDRESSesFor me the STATIC DHCP TABLE should prevail on acccess controlSo help me where is my mistake ?Let me know how can i send you the logsFabrizio
Hi @fabrialare
Do you have registered account on the mycloud-sso.zyxel.com?
You can follow below steps to send us the feedback on the Multy APP.
donei sent to you by fabri.alare@gmail.comeven if my user in reality is fabri.alare@libero.itin any case done0
Hi Jeery have you got any news ?
Hi Jerrydid you check the feedback ?have you got any news?0
- 603 USG FLEX H Series
- 481 News and Release
