Virtual WAN interface or multiple WAN IP method
I have a WAN connection with 5 available static IP addresses. I want to send guest traffic over a different IP than the business traffic. Can I create a virtual WAN and a policy route to do this?
When I try to create a new WAN interface I get a warning about multiple interfaces on a port group. I'm not sure if that means I need to enter a VLAN, but that gives me some confusion...
Hi @nick_patchett,
This feature is still not supported on Nebula mode, you may consider the cloud monitoring mode.
Hello TAPTech,One WAN port group only can have one WAN interface binding regardless it is a virtual WAN or not. It means you cannot add a new (Virtual) WAN interface in a WAN group which already bound to another WAN interface.
Is it the error message you meet? If not, please provide a screenshot of the error message and the settings of your WAN interface, thank you.
James0 -
Hi James,
Yes, that is the same error. I am used to my old USG60 series, where you could add a virtual interface to the existing WAN interface. What options do we have to route guest traffic over a different static IP in the same WAN interface? In this case, I have 5 static IP's available from the ISP.0 -
Hello @TAPTechNebula mode does not support that binding multiple WAN interfaces in one WAN group. In other words, each WAN Group can only have one WAN (virtual)interface.James0
Thank you James, I understand the limitation. Is there another method that you can think of, that can route traffic from a certain internal subnet over a different public static IP?0
I don't get why zyxel did Nebula if its not going to have all the options of standalone?0
Hello @TAPTechDo you mean by Policy Routing? Policy Route allows you to route a certain subnet to a specific WAN interface.
James0 -
Almost. I have WAN1 plugged into a fiber gateway/modem. I have 5 static public WAN IP's available. I want to route all outbound traffic from a certain internal subnet over one IP, and traffic from a different internal subnet over another IP. I could do this relatively easily with my USG60, non-nebula firewall.0
@TAPTech, could you provide your routing topology with a diagram? and what do you encounter when setting it up on Nebula? thank you.James0
I have the same issue : multiple WAN IP’s.
Inbound traffic should be able to NAT depending on witch IP is called.
IE:
1.1.1.1:443 NAT 192.168.1.43
1.1.1.2:443 NAT 192.168.254.43
How do I do this?
(On USG one just create virtual WAN-innerface and NAT them)
You can give the same subnet address in Virtual Server "public IP"
Firewall will do proxy ARP so traffic know where to send
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
