USG Flex 200 - Firewall by WAN
2»
    edited January 2023
    I'm not sure what Zyxel was thinking with a cut down feature for Nebula, I want the kitchen sink. ;)
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    WAN1: Allow HTTP-HTTPS-POP3-SMTP
    WAN2: Allow POP3-SMTP
    Now if i configure a policy routing for POP3 and SMTP they pretend to work only on WAN1 or only on WAN2 but cannot work on both of them, also i have WAN2 that is a backup channel with low limit on monthly bandwidth so i cannot pretend to use it when WAN1 is working and cause to break the monthly limit costantly.
    aalfano_sirm
    Regarding this requirement,  maybe you could consider deploying the USG Flex 200 to on-premise mode and configuring two security policies to meet your requirement, as in the below example:
    WAN1_Policy to allow HTTP-HTTPS-POP3-SMTP services.
    WAN2_Policy to allow POP3-SMTP services.
    Thanks.
  • Pook
    Pook Posts: 153 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    I want to try and help, so essentially you just want SMTP traffic (Port 25) to send out via WAN2?
Nebula Tips & Tricks
