USG Flex 200 - Firewall by WAN
I'm not sure what Zyxel was thinking with a cut down feature for Nebula, I want the kitchen sink.
WAN1: Allow HTTP-HTTPS-POP3-SMTPWAN2: Allow POP3-SMTPNow if i configure a policy routing for POP3 and SMTP they pretend to work only on WAN1 or only on WAN2 but cannot work on both of them, also i have WAN2 that is a backup channel with low limit on monthly bandwidth so i cannot pretend to use it when WAN1 is working and cause to break the monthly limit costantly.
aalfano_sirm
Regarding this requirement, maybe you could consider deploying the USG Flex 200 to on-premise mode and configuring two security policies to meet your requirement, as in the below example:
WAN1_Policy to allow HTTP-HTTPS-POP3-SMTP services.
WAN2_Policy to allow POP3-SMTP services.
Thanks.0 -
I want to try and help, so essentially you just want SMTP traffic (Port 25) to send out via WAN2?0
- 588 USG FLEX H Series
- 476 News and Release
