Application bandwidth limit?
Aaron_ML
Aaron_ML Posts: 9 image  Freshman Member
First Answer First Comment Friend Collector First Anniversary
edited November 2023 in Nebula
I am using NWA110AX for my staff's wifi access in my design studio about 8 months. I like one of the NWA110AX function threat protection in CNP+. It seems I see less unsafe sites recently, feel happy and safe while browsing the websites.
I found there is application bandwidth limit setting in nebula, is it limiting bandwidth usage by connected device or simply by whole access point? Btw, email, video call, file transfer… are used every day in my studio, I need to ensure these applications work smoothly, do you have recommendation for how to configure the bandwidth limit?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi there,
    Limiting bandwidth usage is one function of security service with CNP+ license. AP can control traffic on sites, limit data rate for specific service on AP, keep the bandwidth for higher priority tasks/ applications. The configure rate is applied to each wireless station, for example, if set the bandwidth limit is 5Mbps for Game application, each connected device get the maximum rate as 5Mbps when browsing Game application.
    To configure the bandwidth limit, please follow the steps below:
    Go to Access point > Configure > Security service, and enable Application visibility & Optimization
    Click View Application and configure Bandwidth limit here
    The list of application will be shown by Category, click the Limit icon
    Set the rate by typing the value, click OK and Save.
    We can see the each AP’s usage by click the filter of specific AP.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi there,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
