Give DHCP client a static reservation in NCC?
Using a USG Flex 200 in NCC and I'd like and easy way of giving certain clients a static reservation. In most routers you can just click a check box on a client that's already received their dhcp IP and I can just click a box to make it static and also change the ip to my preferred IP for that client, then clear the arp entry, the dhcp table entry and then reboot the device and it gets the reserved IP I want but so far all I've found is I gotta enter this manually in the interface tab.
Where is the arp table in NCC?
Hi @vining,
You need to manually configure the static DHCP table currently.
And you could find the DHCP leases table in Firewall > Monitor > Firewall via the Live tools.
You can export it as a csv file for configuring the static DHCP table.
Hope it helps.Zyxel Melen0 -
yep, I knew this but was hoping for a more simple solution. It's not so bad doing this manually on a PC but it suck working on a tablet and now a days I hate bringing in a laptop to the job.0
Hi @vining,
Thanks for your feedback. We would like to transfer your idea of giving DHCP clients a static reservation into Nebula ideas section. Please check it here >> https://community.zyxel.com/en/discussion/15695/ip-static-reservation-on-dhcp-client/p1?new=1
Best Regards,
Nami
Nami
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
