Change or switch the Multy Router (X) to a different node
odifoke
I have 3 Multy X, WSQ50 (A, B, C)
I want to change which node the Multy Router (Primary) is on e.g. From A -> C
Can I simply delete it and another will be promoted to Router?
I need to unplug the existing Multy Router (Primary) for an extended period and cannot physically reach or swap the location.
It is not possible. I have had to delete the site and recreate all the settings from scratch with 2 nodes.0
Hi @odifoke
To switch the Main Multy device, need to reset to default settings and reinstall the Multy network topology. It is not available to switch the primary to another node after completing the installation.
- 588 USG FLEX H Series
- 476 News and Release
