problems with HApro
Tue Jan 24 08:25:49 2023 Enter Stand_By mode
Tue Jan 24 08:26:03 2023 Change to Active mode because timeout.
Tue Jan 24 08:26:15 2023 Change to Passive mode because Interface WAN_MAI_GE2 connection check fail. (fail count=1)
Tue Jan 24 08:26:48 2023 Exceed timeout. Device may be still in healthy state but under heavy workloads. Wait for internal timeout: 15.
Tue Jan 24 08:26:59 2023 Change to Active mode because exceeding internal timeout: 15.
Tue Jan 24 08:27:12 2023 Change to Passive mode because Interface WAN_MAI_GE3 connection check fail. (fail count=2)
Tue Jan 24 08:27:44 2023 Exceed timeout. Device may be still in healthy state but under heavy workloads. Wait for internal timeout: 15.
Tue Jan 24 08:27:55 2023 Change to Active mode because exceeding internal timeout: 15.
Tue Jan 24 08:28:08 2023 Change to Passive mode because Interface WAN_MAI_GE3 connection check fail. (fail count=3)
Tue Jan 24 08:28:40 2023 Exceed timeout. Device may be still in healthy state but under heavy workloads. Wait for internal timeout: 15.
Tue Jan 24 08:28:51 2023 Change to Active mode because exceeding internal timeout: 15.
Tue Jan 24 08:29:04 2023 Change to Passive mode because Interface WAN_MAI_GE2 connection check fail. (fail count=4)
Tue Jan 24 08:29:37 2023 Exceed timeout. Device may be still in healthy state but under heavy workloads. Wait for internal timeout: 15.
Tue Jan 24 08:29:47 2023 Change to Active mode because exceeding internal timeout: 15.
Tue Jan 24 08:30:00 2023 Change to Passive mode because Interface WAN_MAI_GE2 connection check fail. (fail count=5)
Tue Jan 24 08:30:33 2023 Exceed timeout. Device may be still in healthy state but under heavy workloads. Wait for internal timeout: 15.
Tue Jan 24 08:30:44 2023 Change to Active mode because exceeding internal timeout: 15.
Hi @nikita92,
Greeting forum, Please kindly provide your firewall module and frimware version.
Also print the output messages by the below command:show device-ha2 logshow device-ha2 trace-logshow device-ha2 statusThank you
Kevin
Seems the current failover count reached the max. failover count. You can try to use the command to reset the counter.Router> debug device-ha2 send failover 01
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
