Zyxel Drive : How this is working ? I get an 205 error.
sitro
hello,
I configure the Zyxel Cloud . it seems ok (see screenshot).
On my smartphone the app Zyxel Drive (inside or outside my metwork )
I see first the Nas connected then the list of Folders .
But when I select a folder , I get a error message n° 205 (see screenshot).
All permissions are read and write for the cloud user.
What's the problem ?
You can check out this similar article about your issue: https://community.zyxel.com/en/discussion/comment/47507#Comment_47507.Additionally, consider trying a different router to see if it resolves the issue with your local network.0
Hi,Thanks for the answerBefore doing any blind hardware changes to see if it works. I would like to know what the error numbers correspond to, I see that one is 104, the other 119, and me 205 with the single answer changing the router. I don't think that's how you can solve a problem.
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 305 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
