[Notification] In versions 6.45P0, 6.50P0 and 6.50P1, repeater AP can’t upgrade firmware via Nebula
Zyxel_Jay
Zyxel_Jay Posts: 226
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
image  Zyxel Employee
edited May 2024 in Wireless
Issue Description:
We identified a problem with firmware upgrades on repeater APs in versions 6.45P0, 6.50P0, and 6.50P1. When attempting to upgrade the firmware via Nebula, it will display a firmware upgraded fail message and reboot. the repeater AP is unable to upgrade firmware.
Noted: This issue has no impact on the overall functionality of the product and doesn't affect the firmware upgrades of root AP.
Affected Scope:
Models:  NWA110AX, NWA210AX, WAX510D, WAX610D, WAX630S, WAX650S, NWA220AX-6E, WAX620D-6E, WAX640S-6E, WAX655E
Firmware version: 6.45P0 ,6.50P0 and 6.50P1
AP Role: Enable Smart Mesh > Repeater
Solutions:
Upgrade the firmware to version 6.50P2
There are 3 ways to upgrade the firmware.
1.     Connect the repeater to the ethernet that can reach internet and upgrade to a firmware version to 6.50P2 via Nebula
2.     Upgrade Firmware by FTP
Please refer to this article.
https://community.zyxel.com/en/discussion/15069
3.     Upgrade Firmware by ZON
https://community.zyxel.com/en/discussion/15648
Please note, the official download link for the AP model bin file for firmware upgrade is available at: https://www.zyxel.com/global/en/support/download
  • Zyxel_Jay
    Dear all
    If you are unable to locate the 6.50P2 firmware on our website, you can download it by following the instructions for your specific AP model on this page.
    NWA110AX V6.50(ABTG.2)
    NWA210AX V6.50(ABTD.2)
    NWA220AX-6E V6.50(ACCO.2)
    WAX510D V6.50(ABTF.2)
    WAX610D V6.50(ABTE.2)
    WAX620D-6E V6.50(ACCN.2)
    WAX630S V6.50(ABZD.2)
    WAX640S-6E V6.50(ACCM.2)
    WAX650S V6.50(ABRM.2)
    WAX655E V6.50(ACDO.2)
  • DanniKool
    DanniKool Posts: 60
    First Answer First Comment Friend Collector Eighth Anniversary
    image  Ally Member
    ftp> put c:\nwa110\650ABTG2C0.bin
    200 PORT command successful
    226-Could not open data connection to port 49546: Operation timed out
    226-firmware verifying...
    226 file damaged!!
    We also have 2 other customer sites that we can't remote access unless involving customer. Not acceptable!
    How to solve?
  • Zyxel_Jay
    Can you share how you assist customers in upgrading firmware via FTP?
    In our experience, we suggests that if you are inconvenirnt to involve the customer or site visit, you can use gateway to do VPN or remote access to the customer's computer on the same network as the AP.  And you can do the ftp successfully.
    The firmware file has been tested and confirmed to be undamaged. Please let us know the status of your connection.
  • DanniKool
    DanniKool Posts: 60
    image  Ally Member
    Our customers are just normal users with no technical insight. That's why it's inconvenient to involve them because they ask stupid questions to why this needs to involve them etc.
    I was able to VPN into one site and doing a FTP transfer in a command prompt - that failed as explained. I was able to do a FTP transfer with WinSCP with success.
    I have 2 other sites under the same organization, where i'm not able to VPN into. I unfortunately had to involve the customer where we attached a network cable, did the firmware upgrade and unplugged the cable again. This customer did ask funny questions about this!
  • Zyxel_Jay
    Hi @DanniKool
    I'm sorry that this incident has caused inconvenience for you and the user. We will continue to strive to provide better and more stable cloud control solutions to avoid similar events from happening again. Thank you for your assistance this time. If there are any issues, feel free to raise them.
  • mMontana
    mMontana Posts: 1,512
    image  Guru Member
    To all Zyxel represenatives.
    Hiccups and problems happens, all the time. But the more issues and limits Nebula encounters, the less I'm considering Nebula as an option for managing devices.
    Because the number of issues directly (on site) managing devices is… lower, most of the times. If Nebula isn't at least on par compared to a small pc with a remote assistance tool… Nebula is not worth the effort for some kind of customers.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,851
    Hi @mMontana ,
    Thank you for sharing your thoughts on Nebula.
    Nebula is designed to provide convenience and efficiency in network management, offering centralized control and anytime-anywhere access. We are committed to continuously enhancing its capabilities based on user feedback.
    Your insights are highly appreciated, and our goal is to make Nebula a robust and reliable network management tool. If you could provide more details about any specific suggestions or ideas you have on Nebula, it would greatly assist us in offering more targeted assistance and further improving Nebula for all users. Your input is valuable to us.
    Please note that the issue reported in this thread has been addressed in the 6.50P2 firmware update.
    Zyxel_Judy
