I have an F1000 Router and looking to know how to update the firmware
ELDIABLO
in Home Router
Hi I have an eircom F1000 ZyXEL router and i what to update the firmware and but it into bridging mode.Can you please advise the steps i should do.
Hello @ELDIABLO
I don't work for Zyxel but I have found from https://www.boards.ie/discussion/2057302483/howto-unlock-your-eircom-f1000 that an Eircomm F1000 is a Zyxel VMG8324 device.
There is a whole thread at https://forum.kitz.co.uk/index.php/topic,13930.975.html about VMG8324-B10A.
One quote from that thread is as follows:
"Broadband Hardware / Re: ZyXEL VMG8324-B10A Firmware
« Message by dmcdonnell on January 27, 2018, 11:27:06 AM »If you have a locked Eircom F1000, you can download a modified copy of the latest (v.20) firmware by following the link below. The modification brands the firmware as Eircom so as to be acceptable to your router."
https://drive.google.com/file/d/1JW-RKap6boYfnhIXeNeS_wFePYfIxcjQ/view?usp=sharing
but that Google Drive link does not work any more.
The Zyxel VMG8924 firmware v28 available at https://support.zyxel.eu/hc/en-us/articles/4403361365778-Advanced-Downloads-for-CPE-devices could work in the VMG8324.
The download link there is broken, but the same firmware is available at https://www.studerus.ch/de/support/downloadcenter and the release note says that it supports the VMG8324-B10A and the VMG8924-B10A.
There is a 2013 user guide for VMG8324 at http://prodotti.zyxel.it/USERSGUIDE/ZYXVMG-8324.pdf
There is some other user help about bridging at https://kitz.co.uk/routers/zyxel_VMG8324-B10A_bridge.htm
But I have not tried any of this myself.
Kind regards,
Tony0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
