DynDNS with DNS-O-Matic Provider
is it possible to use the DNS-O-Matic Provider? It is a simple GET Request with BasicAuth. But I didnt get it to work.
https://dnsomatic.com/docs/api
Thanks!
Best baba
Is it possible to see the log files of the request to the DynDNS provider? Other Zyxel devices support DNS-O-Matic natively: https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=017612&lang=EN0
Hello @babaDNS-O-matic is an integrated DDNS service, that includes DynDNS, NO-IP... And Nebula does not support DNS-O-Matic service, I suggest that select DynDNS as the DDNS provider, and input DynDNS credentails and settings.James0
Hi @Zyxel_James,I do not understand your answer. My DynDNS provider is Cloudflare. Nebula natively supports only older providers, which offer no new features. Since Cloudflare has a complex request to change the IP address, I put DNS-O-Matic in between.When I enter DynDNS as provider in Nebula, I can't enter a URL anymore. The Request of DNS-O-Matic ist the same as DynDNS, but the URL ist different.Can I see the logs of the DynDNS requests in Nebula? Which settings can be configured at "Additional DDNS Options"?0
Hello @babaDo you mind explain "Cloudflare has a complex request to change the IP address, I put DNS-O-Matic in between"?Moreover, you can connect to the device via ssh and inputRouter# show logging entries keyword DDNSThen you can check DDNS-related logs.Please enable Zyxel support access for further checking.James0
Hi @Zyxel_James,
Do you mind explain "Cloudflare has a complex request to change the IP address, I put DNS-O-Matic in between"?Cloudflare needs a PATCH request to change the IP-Adress of the A record. Thats not a simple GET request as most DynDNS providers have. Have look at: https://developers.cloudflare.com/api/operations/dns-records-for-a-zone-patch-dns-record
To change the IP-Adress of the A record in Cloudflare with a simple GET Request i have connected DNS-O-Matic between Nebula and Cloudflare. With DNS-O-Matic I can update the IP-Adress with this simple GET request:
Output of the log:Router> show logging entries keyword DDNS
No. Date/Time Source
Destination
Priority Category Note
Source Interface Destination Interface Protocol
Source Country Destination Country
Source CountryCode Destination CountryCode
Message
8 2023-02-02 22:04:42
notice built-in-service DDNS
Update the profile DDNS has an unknown result.
9 2023-02-02 22:04:42
DDNS profile DDNS was get server response: [RESPONSE]\x0acode = 200\x0adescription = Command completed successfully\x0aqueuetime = 0\x0aruntime = 0.047\x0aE.
The log said that the command completed successfully but the IP-Adress did not change in DNS-O-Matic. When I open https://username:password@updates.dnsomatic.com/nic/update in the browser, the IP address is changed correctly.
Zyxel support access is enabled.
Thank you!
Best, baba0 -
Hello @babaI found out your DDNS URL settings miss a question mark, it should be https://updates.dnsomatic.com/nic/update?Could you try again and check the logs by command "show logging entries keyword ddns"0
Hi @Zyxel_James,
the questionmark should not be mandatory:In a URL, the question mark (“?”) divides the address of an object and the set of words used in the query.In My DynDNS URL is no query parameter so no ? is needed.
Consider the following examples:
However I've added it and got no new log messages. Can I test the DynDNS request without restarting the internet / router?
Log:Router> show logging entries keyword ddns
Destination
Message
===============================================================================Best regards
@Zyxel_James still no logs after reconnect0
Hello @baba
I can confirm the DNS-O-MATIC service is available, please refer to the screenshots.
Check the DDNS-related logs by input show logging entries keyword ddns
As I tested, If you remove the question mark, the device won't able to find the URL
Hi @Zyxel_James ,
thank you four your answer. The password is correct. I've tried to replace the email with the username but i get no loggs after saving in Nebula:
Destination
Message
How can I trigger the dyndns request?
Thanks!
Regards, baba
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 353 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
