XGS1250-12 and SFP+ PM7000-01 XGS-PON transceiver?
2»
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    Hi @HS1542
    Apology for the previous incorrect information.
    Before you get the gateway and the SFP module, the ISP has recorded the serial number of the PM7000-01 and finished the registry process.  When the connection links, the ISP will verify the Serial number of the SFP is as same as the registry information or not.
    I will help to clarify if the XGS1250-12 can link up with PM7010-R0 and update the result to you.
    Zyxel Melen
  • Zyxel_Melen
    Hi @HS1542,
    Apology for the late reply. I took some time to build the test surrounding.
    My test result is that the PM7010-R0 can work with XGS1250-12, and the packets can be forwarded.
    So, you might need to contact your ISP for changing the Serial number of the SFP module.
    If there have any questions, please feel free to ask.
    Zyxel Melen
