Is there really a limit of 20 Static IPs???
I'm starting to have serious misgivings about buying these NSG50 gateways instead of USG40s. First I discover you can't apply different Content Filter/App Patrol profiles to different networks.
Now I'm trying to setup a network with a number of existing static IP devices and I get an error saying the limit is 20 items? Seriously??? Is there no way to configure more than that? Why such an arbitrary limit?
And why is the default font/view such you can't see the whole IP and MAC in the form? Its so tedious having to select and shift to make sure the data was entered correctly. If I zoom the page in a lot I manage to get MOST of it visible, but the last octet of the MAC never is.
It's annoying but if you can connect your hosts under different VLAN interfaces, then that should allow you to set more static host addresses.
And I totally agree with the ip/mac field being too small... There is definitely room for improvement.1 -
Hi Thanks for your suggestion @CrazyTacos
Hello, @itxnc about your first question I have reply it on your the other post.
We'll have the feature enhancement about the maximum number of static DHCP list, the schedule is still under the discussion same as GUI display matter I'll move it to the idea section, thank you.
5 -
Hi @itxnc and @CrazyTacos
The entries for DHCP static entries have been expanded. Now it will follow according what the NSG mode supports:
NSG50:64
NSG100:96
NSG200:256
NSG300:300
Hope this helps you ?
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
