[NEBULA] Deauth by STA Timeout reason 2
Hello Dean,
The strange thing here is that the client is only disconnected while being fully active. While idling (over night for example) it stays connected.Nebula_Dean said:@DerLord
The log is almost same as what @Carlos4311 said, if a station idle for too long, then the AP will de-associate the client.
I'd love to, but I only have the free version of Nebula to be honest. The button for exporting logfiles is grayed out for me. If it helps; the S6 Edge is showing these network capabilities: "802.11ac, 802.11k/v".Nebula_Dean said:@DerLord
Is it possible to provide a snippet of the eventlogs while this happened? I will need to check unfiltered logs before and after the event 2 hours. Also I'll need sometime to try reproduce this locally, especially finding a S6 edge.
No other client complained about this. I looked up the logs and all the clients showing the "reason 2" error are either reconnecting within a few seconds or have left the site anyways.Nebula_Dean said:@DerLord
Another thing, did other androids or iOS device have the disconnection? and were they able to retry connecting or jump to another SSID?
For some reason I'm getting a few "prev-Auth failed" errors (reason 2 again) now, but that doesn't seem to be critical.
I'm only having one active SSID on my site sending on 5GHz and 2.4GHz (Concurrent operation with band select active; great feature by the way!).
For me it looked like an error on the NIC aswell, but the client claims that it never happens at home.Nebula_Dean said:
@DerLord
When the station needs wifi on/off to recover, this is likely to be an NIC issue on the device, normally it should skip to another SSID if disconnection happens or internet loss.
She is using a regular "Telekom Speedport W724V Router", sending the same SSID on 2.4 and 5GHz.
If this issue would persist everywhere, I wouldn't have bothered any of you with this strange problem. I just can't figure out where the problem comes from.
If it helps:
The configuration of my site is pretty basic with WPA2-PSK authentication. No MAC-Filters, no isolation.
Android devices appear to activate Fast Transition (FT) per default, but turning this off doesn't seem to change anything.
I'm sorry to be that unhelpful.
Thank you for helping me out anyways!
Best wishes,
Niklas0 -
Hey Niklas @DerLord ,
As an alternative, perhaps you could filter the MAC of that S6 edge and copy paste it into and excel file, I am trying to look for abnormal log entries at or near the time the issue happened.
Since you mentioned other clients are not having this issue, we can focus on this client for now.The strange thing here is that the client is only disconnected while being fully active. While idling (over night for example) it stays connected.I do hope this is something limited to samsung, but to be careful I think it is best to wait until further tests been done before getting to any conculsions.
Anyone with an S6 Edge in hand able to test this out too?
Hello again,Nebula_Dean said:Hey Niklas @DerLord ,
thank you for your (impressingly fast) answere.
I feel a little stupid for asking, but what exactly should I copy-paste into the excel sheet?
Do you only need the MAC to get direct access to my logs or do I need to take some further steps?
Or should I mark everything on the "Event log" page surrounding the disconnection message?
Can I "PM" the Excel-Sheet to you or shall I attach it to this thread?
Sadly I don't know anyone else.Nebula_Dean said:Anyone with an S6 Edge in hand able to test this out too?
Maybe someone else reading this thread can help us out.
Best wishes,
Niklas0 -
Hello again,
after a lot of chatting with @Nebula_Dean who provided absolutely outstanding support (this man deserves a raise!) we came to following conclusions:
1. The state machine of the Galaxy S6 Edge's NIC (@Nebula_Dean got one himself just for double checking) is kinda bugged and doesn't provide acceptable fallbacks in error cases.
2. The Galaxy S6 Edge doesn't really support advanced features like 802.11k/v/r, but attempts to use them anyways (with horrible outcomes).
So @WaYne was indeed right about the 802.11k/v/r. Maybe the error persisted because I had a few problem on my network's side anyways.
After disabling 802.11k/v and 802.11r and rebooting the AP, the error hasn't shown up again.
I wanted to test if either 802.11k/v or 802.11r is producing the error, but "sadly" the phone died yesterday.
The client is now using an One Plus 6 and hasn't faced any issues since then.
Thanks to all of you for your help (again, especially @Nebula_Dean who clearly had a lot of more important work to do, but still provided every imaginable support)!
If someone faces an issue like this again, disable 802.11k/v/r like @WaYne suggested and everything should work out as expected.
Best wishes and thanks again,
Niklas3 -
Hi there,
is there any news to this issue, please.
I'm encountering the same problem outlined above, with a cell phone that is roaming.
However, this only started happening now, without any changes to my network. Could this be a firmware issue? Please let me know if disabling is 802.11 k/v/r is the only way to prevent this, and/or how any resulting roaming issues might be prevented/minimized. Thanks!
Kind regards0 -
@stoph3d What we did back then was creating a separate 5 GHz SSID which had k/v/r disabled. We then used this SSID only for this specific device. This at least enabled us to let all the other devices roam and get the erroring device to work as it should.
I sadly can't tell anything about updates to APs or Nebula, and as this thread is officially resolved, I'm not sure if any of the Zyxel employees will jump in again to shed light on this matter.0 -
stoph3d said:Hi there,
Kind regardsHi there,
Roaming is the behavior of stations handle with the APs. When station gets the bad signal, it decided whether roam to another AP.
When disable 802.11k/v/r, the station use the roaming capability by itself only, it means no roaming support from APs.
The best way to minimize the roaming is the good deployment let the station has the good signal (good signal must higher than-70dbm).
In case there is any abnormal issue or log that you saw, you can share with us and enable customer’s Zyxel support by going to the left sidebar > Help > Support request > Invite Zyxel support as administrator, save the changes for us to check.
Zyxel_Judy
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
