USG60W No 5Ghz Broadcasting
Not exactly sure, but notice a related thread from 2018:
https://community.zyxel.com/en/discussion/1433/usg60w-wifi-problemAs you mentioned that the symptom was gone after re-uploading 4.31 firmware, something might go wrong in previous firmware uploading process.0 -
Also worth asking: Any change in this problem if you downgrade to previous firmware version?0
I have 3 devices, same issue all different firmware versions. I've tried upgrading firmware - no luck. Will try an older firmware and hope for the best lol0 -
Hi @AndreYPB,We use the default configuration file, disable 2.4G on USG60W and leave 5G only. Use the latest firmware version 4.73(AAKZ.0) to run the test and wireless client (iPhone) is able to connect to SSID successfully. Hence, there is no problem with 5G on USG60W.
Emily,
So you are telling me that 5G will only work if 2G is disabled? This is ridiculous. We have some legacy devices that only work on 2G. The unit has two radios, why can't both work?
At a colleagues site that runs firmware 4.10 I've seen 2G and 5G working at the same time. This is clearly a bug that should be given some attention.
I will try your suggestion as a test to see if the unit is faulty. I don't want to downgrade to 4.10 as that only shows support for 5g at n & a, whereas the newest firmware has an option for ac and ax0 -
@PeterUK Exactly, my company have been a ZyXel partner since 2013, and we've used ZyXel since 2009. US60W when it first came out was excellent. I recall setting up an office of 10 users that connected only to that via wifi. These recent models on the 'latest' firmware have poor wireless range... and poor wireless performance in general.
I have 3 USG60Ws running the latest firmware, 5G doesn't work on any of them. I done as @Zyxel_Emily suggested and disabled 2.4G... now I can see 5G or rather, only my laptop sees it. Latest iPhone and Samsung both can't see it. even on a/n. Connect laptop to it, low signal and 0 performance, despite being sat a metre away from it.
From where I'm sitting (I could be wrong), but it appears like the latest firmwares weaken the built in wireless, so one has to invest in additional APs at cost. If this is the case... I'll have to consider partnering elsewhere.
(Feeling quite frustrated, so pardon the rant).0 -
Hi @AndreYPB,In my test, the reason I disable 2.4G is that I'd like to prove iPhone is forced to connect to 5G. Actually, you can keep both radio 2.4G and 5G enabled. To check if 5G is able to broadcast, you can use the command to check Tx power of index 2.Router> show capwap ap all statistics
@Zyxel_Emily I understand. However, I am using a wifi-analyser that shows all broadcast signals. I have created a different SSID to broadcast 5g... This does not come up with the wifi analyser or on the laptop or iphone. In the Zyxel Ap information, it shows 0 on 5g stations.
As I said, if I disable 2.4g - then 5G starts broadcasting, however, when I connect to 5g - the signal is half, the performance is 0 - I get the correct IP address, but internet performance is diabolical.0 -
Hi @AndreYPB,Please collect diagnostic file after the issue happened. Then send diagnostic file and startup-config.conf to me in private message. Thanks!0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
