i cant update my router VMG3625-T50B
beka
During the VMG3625-T50B firmware upgrade I'm facing the following error:
Image uploading failed. The selected file is an illegal image. You may press 'Cancel' to upload another firmware image file, or press 'OK' to reboot to recover normal operation.
My Current Firmware Version: V550ABTL0b2r
Newest version: V550ABPM6C0
or :5.50(ABPM7.1)C0
Could you help me?
Hello @beka
Unfortunately, the newer version is incompatible with the firmware version you already have.
- the newer version is ABPM (therefore uncustomised) whereas you have ABTL (which is a customised firmware.)
If you can, please contact your Internet Service Provider (ISP) for a customised firmware update.
Kind regards,
Tony0 -
My current firmware version is V550ABTL0b2r did you know where can I find it? beka ,onesmartsheep10
My current firmware version is V550ABTL0b2r did you find it? beka ,onesmartsheep10
You gave me this version but it doesn't work
- 431 Beta Program
- 2.6K Nebula
- 168 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 293 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 408 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
