USG60W disconnect and crash
PeterUK
What with the USG60W being EOL this might not get fixed but I post anyway.
Was one V4.73 now on V4.73(AAKZ.0)ITS-22WK50-r106743
So setup is with USG60W built-in wireless down a VPN tunnel to VPN300 doing speed bursts at speedtest closing/refreshing before it ends and running it again over and over.
The problem seems to be that the VPN is under heavy load that the USG forgets the wifi causing a disconnect and crash.
Test devices
Sony XPERIA 5 2 mostly disconnects
Tp-link Archer T9UH can cause the USG60W to reboot but since have not cause this to happen again.
Logs with disconnects by Sony phone
70
2023-02-09 09:19:20
info
STA Disassociation(2:PREV_AUTH_NOT_VALID) by STA Timeout. MAC:3C:01:EF:00:00:00, AP:Local-AP, interface:wlan-1-1, SSID: Zyxel_2G, Tx/Rx:81389025/5695538 Bytes, session time:0H:01M:32S
Wlan Station Info
125
2023-02-09 09:17:48
info
STA Association. MAC:3C:01:EF:00:00:00, AP:Local-AP, SSID: Zyxel_2G
Wlan Station Info
157
2023-02-09 09:17:03
info
STA Disassociation(2:PREV_AUTH_NOT_VALID) by STA Timeout. MAC:3C:01:EF:00:00:00, AP:Local-AP, interface:wlan-1-1, SSID: Zyxel_2G, Tx/Rx:1043682490/60988405 Bytes, session time:0H:10M:58S
Wlan Station Info
    edited February 2023
    Update have now caused a crash/reboot of the USG all I was doing was a ping on Tp-link Archer T9UH and speed test by phone by closing/refreshing speed test app before it ends and running it again over and over.
    Have the Diagnostic run after the USG booted back up if needed for you to have a look at.
  • Zyxel_Cooldia
    Hi @PeterUK,
    Can you send me diag-info in PM for further checking.
    Sent
    I'm thinking the FLEX/ATP 100W might have the same problem
  • Zyxel_Cooldia
    Thank you for updating me on the test result. After changing the remote policy from an IP range of 0.0.0.0 to 255.255.255.255 to a subnet, there were no more reboot crashes.
