nas326 not creating volumes
Bünyamin
On the NAS326 device, I cannot create a new volume. My disks can work normally in Windows and I can add and delete files.
I am using the latest software version? What is the reason of this ?
Did you solve the problem?
You can check if you're using enough power supply for your NAS.
If you try with only one disk in the NAS and create a Jbod type, I think it will work.0 -
ikubuf said:You can check if you're using enough power supply for your NAS.
If you try with only one disk in the NAS and create a Jbod type, I think it will work.Hello,I did what you said. I removed one of the discs and re-executed the steps but still didn't work. Then, when I follow the steps on the other disk, the volume creation is done. I think the disk is corrupt or something is wrong for the NAS326. The disk is working fine in Windows.0 -
Has the problem been solved? How? I have the same situation.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
