IPv6 - router advertisement frequency [XMG3927-B50A]
flip
in Home Router
Anecdotally, enabling IPv6 impairs the battery life of phones/tablets on my network.
After analysing traffic on the network, I note that router advertisements are sent every 10 seconds by the XMG3927. The default for radvd is between 200 and 600 seconds. Best practice suggested by RFC 7772 for networks with phones/tablets is c. 7 per hour.
I'd like to request any firmware update revert to the default interval in radvd.
Thanks!
p.s. It would be ideal if you could upgrade radvd (to a version greater than v2.19) so we might also benefit from unicast router advertisement responses to router solicitations (enabled by default), as recommended by RFC 7772.
Model: XMG3927-B50A
Firmware: V5.17(ABMT.6)C0
Thanks!
Model: XMG3927-B50A
Hello @flip
Would you be ok if the default intervals for radvd was like those in this man page? https://linux.die.net/man/5/radvd.conf
Thoughts?
Kind regards,
Tony0 -
Hi @tonygibbs16Yes, I think the radvd defaults are perfectly sensible - I just wish the firmware defaulted to them!1
- 3K Nebula
- 228 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 645 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 54 Wireless Ideas
- 7.1K Consumer Product
- 303 Service & License
- 496 News and Release
- 93 Security Advisories
- 4.9K FAQ
- 89 About Community
- 110 Security Highlight
