NWA220AX-6E - Wifi 6E ok, but very bad on ipad and iphone
i have 2 x nwa220ax-6e at home
Very good connection on my laptop with 1300mbps on speedtest.
But on other devices like, Iphone or ipad, not Wifi6E, i have a very bad connection like 30mbps...
Hi @jeromarsan,
NWA220AX-6E is Band-Flex supported model that can be configured as either 5GHz or 6GHz. It means the radio will be 2.4GHz + 5GHz or 2.4GHz + 6GHz.
When you set the band as 6GHz to experience Wifi 6E performance, the 6E non-supported clients just can connect to 2.4GHz, so they don’t get the good connection.
In case you’d like to have good performance for all clients, you can set the band as 5GHz by going to Radio settings > BandFlex > Choose the model > Edit
Choose Band as 5GHz > Update
In case, if you meet other issues/ symptoms, please let us know and provide us your Org/ site name by click to my account > Private message.
Zyxel_Judy
I send you private message
Thanks 0 -
Hi users,
NWA22AX-6E is Band-Flex model, so users can be flexible to choose 2.4GHz + 5GHz or 2.4GHz + 6GHz.
With the scenario that need to use 2.4GHz + 5GHz + 6GHz at the same time, we recommend referring to WAX640S-6E - a Tri-Band Wi-fi 6E AP.
Zyxel_Judy
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
