Armor G5 VLAN Tag
saumitra
in Home Router
I have bought the Armour G5 for using as a router with my FTTH connection which arrives to an ONT but i needed to use the VLAN tag option in order to connect to the Internet. As per the guide page which i add here as screenshot it is there but alas i don't find while setting up the router. so now i have to return unfortunately as it doesnt connect to internet anyway, what a pity
We are unable to use the device for connecting to internet at the moment. Could this feature be enabled in a new firmware?
Any update? This feature can reach more customers and money so why can't be implemented?0
Hello, The important thing is that I think that this deficiency or such a feature will be fixed with a software update, it shouldn't be that hard, I hope a new version firmware is given as soon as this deficiency is fixed. Otherwise, it remains to return the zyxel argor g1---g5 devices we have purchased. Kind regards.
The Armor G1 Armor G5 device does not support VLAN tagging. If this feature is essential to your requirements, please contact the windows from whom you purchased the Armor G1 device to initiate a return.The NBG7510 router, which provides VLAN tagging functionality.You can refer to the device specifications to ensure it meets your requirements.
Zyxel
In the future are you going to add the vlan tag feature or not?
thank you very much for your availability
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
