Zyxel NAS326 NAS Mini Tower Ethernet LAN Black ASIN: B01A98WGRM
Man_Specialist
Man_Specialist Posts: 1 image  Freshman Member
GENTILISSIMO STAFF, AVREI BISOGNO DI VOI PERCHÉ IO CREDO DI AVER FATTO TUTTO CORRETTAMENTE ESEGUENDO L'ISTRUZIONI, MA CON NESSUNA APPARECCHIO RIESCO COLLEGARMI AL NAD , NÉ USANDO IL TABLET CON ANDROID 11, NE USANDO IL TELEFONO CON ANDROID 12, NEANCHE USANDO IL MAC CHE RIESCO A VEDERLO MA NON RIESCO A COLLEGARMI ANCHE SE PREMO IL PULSANTE PER RIMANERE DENTRO NEI 5 MINUTI , IN TUTTI I MODI NON RIESCO A COLLEGARMI SE MI AIUTATE IO VI ALLEGO IL ROUTER CHE USO, VI ALLEGO I PONTI PER ALLARGARMI I SPAZI DEL WIFI E DOVE MI SONO COLLEGATO CON IL CAVO SIA SUL ROUTER CHE NON FUNZIONA E NON SI ACCENDE LA LAMPADINA VERDE DELLA SCHEDA DI RETE DEL NAD MA COLLEGANDOMI AD ALTRI PRODOTTI CHE MI ALLARGANO LA ZONA CHE VI ALLEGO QUELLI MI SI ACCENDE LA LAMPADINA VERDE DELLA RETE DEL NAD MA NON RIESCO ENTRARE NEL NAD E CONFIGURARLO IN NESSUN MODO TRANNE QUELLO CHE VOI CHIEDETE IL NUMERO SERIALE E L'ID DEL PRODOTTO MA IO NON SO DOVE TROVARLI SE GENTILMENTE MI AIUTATE A CAPIRE PERCHÉ NON RIESCO A FARLO FUN
RIMANGO IN ATTESA DI UNA VOSTRA RISPOSTA URGENTE GRAZIE.
Cordiali saluti
Lanza Luca
  • ikubuf
    ikubuf Posts: 143 image  Ally Member
    The USB ports on the NAS are intended for external drives  Unlike other NASs.
    To add the NAS into your network, you can put the NAS directly under the router or AP and connect directly with RJ45 ethernet cable.
