Change configuration
Mark_Sheephouse_37
in Nebula
I have 2 access points and one keeps showing an orange alert. When I click on it and go to Access point/Monitor/Access point under Link: there is the following 'Uplink: 100M/Full'. If I hovver on the Orange warning triangle it says 'Uplink currently operates at a lower speed 100 Mbps'. When I look at the other Access point it is green and says 'Uplink: 1000M/Full'. ie 1000 not 100. I cannot see anywhere where I can change the setting from 100M to 1000M. FYI I have Swish Full Fibre with Download and Upload speeds of 500Mbps. Any help greatly appreciated.
Maybe a bad cable?1
There is no configuration to change the setting from 100M to 1000M. The uplink alert based on the current uplink status.
Recommend you changing a cable/ the port that problematic AP connected to check whether the issue solved.
Zyxel_Judy
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 304 Service & License
- 496 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
