Using my modem/routeur VMG3625-T50B as a repeater
I'm connected to the internet in my entrance room with a modem/routeur Zyxel DX3301-T0.
I have a switch in my office that is too far away from the entrance to be connected via ethernet plug.
I have a modem/routeur Zyxel VMG3625-T50B that I want to use as a repeater, connected to the switch via ethernet, that should be able to connect to the entrance modem/routeur via WIFI to give internet access to the machines connected to the office switch.
The model has a repeater function, however when I set it up, I cant find the way to connect it to the existing WIFI.
How should I proceed?
Thanks!
Hi there
In my understanding, if you set the device to be a repeater, you need to setup the WIFI connection by pressing the WPS on both devices and make sure these two devices connected successfully via WIFI.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
