WX3100-T0 separate settings for 2.4G and 5G
Orlang
Orlang Posts: 4 image  Freshman Member
edited August 2023 in Home Router
I have the following problem, on my WX3100-T0, the option to disable the same settings for 2.4G and 5G wireless networks is greyed out ("Keep the same settings for 2.4G and 5G wireless networks" - is on and not active).
The access point is connected to the router via LAN, the operating mode is "AP Mode". Firmware Version: V5.50(ABVL.1.1)C0
The "Hide SSID" options are also inactive with the comment “Hide SSID does not support WPS 2.0. You should disable WPS in WPS page”, even though WPS is not used.
How to enable the ability on this AP to use separate settings for 2.4G and 5G wireless networks to make two separate SSIDs for 2.4G and 5G?
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Screenshot from your AP or Nebula console?
  • Orlang
    This is an AP console.
  • mMontana
    Maybe this option is disable because of another setting?
    I do not have direct experience with this model.
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    This is a MESH device and I don't think you can disable it.
  • manu_manu
    manu_manu Posts: 1 image  Freshman Member
    @Orlang Yes, here is the solution. In order to do what you are looking for:
    Go to the top right hand corner and select the collapsible menu
    Then select Network Setting > Wireless
    Once there, go to MESH tab and deactivate it. Apply the change.
    Once done, now go to WPS tab and now you will be able to use the graphical button to deactivate WPS. Simply deactivate it, hit apply.
    Go to General tab, and check the hide SSID checkbox, hit Apply again.
    Finally, go back to the top right hand corner collapsible button, select Connection Status > Wifi Settings > click the blue arrow and check the Hide WiFi network name checkbox > Save.
    And you are done!
    Have a great day/evening depending on where you are!
