Multy M1
cbm64
What is the max throughput of a Multy M1 on PPPOE? In a test it is maxing at ~330Mbps? I am connected to a 1Gbps FTTP. The cable between the FTTP and the Multy is high quality CAT7 and only 1M in length.
Is this just a test rather than a speed test?
Hello @cbm64
The specifications at say that Multy M1 is up to of 574 Mbps on 2.4 GHz if you have IEEE 802.11AX and up to 1201 Mbps on 5GHz if you have IEEE 802.11AX.
In practice, interference and distance will limit speed.
Kind regards,
Tony
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
