Nebula event log not working anymore
Posts: 51  Ally Member
edited November 2023 in Nebula
Hi support
Since around one week I cant see any entries in the event-logs.
steps to reproduce:
click on a client e.g MacBook-Pro
click history, event-log
no details appear in the event-log page. it can be reproduced with any client in the network. when I click on an AP and then history - event log it shows entries.
could you please have a look at my site, the org is called Graf, the site Dietikon. I sent an invitation via the Nebula-GUI. I activated a trial of Nebula Pro which expired around 2 weeks ago, maybe this is the reason why this happened.
rebooting the APs several times didnt help.
all the best
Andrew
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
  • Posts: 2,143  Zyxel Employee
    Hi Wookie,
    We found the same the symptom as you shared, and it should be a display problem, so we’ll fix it and tell you when it is done.
    In case, you’d like to check the event log of specific client, please directly go to Access point > Monitor > Event log > and then input the client MAC into Keyword box > click Search as a workaround before we fix problem. 
  • Posts: 51  Ally Member
    Hi Judy
    many thanks for the quick reply, will do it according your suggestion until fixed.
    Hi Judy
    do you already have news/timeline when the error will be fixed?
    edited March 2023
    Hi there,
    As the schedule, the issue'll be fixed on March 7, 2023.
    Thank you for your patience!
    Hi there,
    We fixed the issue already. Please help to confirm that.
    Thank for your patience!
    Hi Judy
    many thanks, I can confirm that the issue is fixed.
Welcome!
Welcome!
