Nebula Cloud - License update or replacement from PLUS to PRO
Dear all,
Is there a way to update license for device which was already assigned with one previously?
In my case I do have a switch, managed by Nebula Cloud. Initially we have assigned PLUS license to this switch, however later on we purchased PRO license which we added to Nebula Cloud, however even when we try to assign this license to the same switch it is seen as Inactive and still PLUS license is used by the switch.
Because PLUS license is active than whole Nebula Cloud platform is also locked to PLUS license features.
It can't be upgraded to PRO until there is a device with active PRO license in place. Which we do have, however can't move it to activate state on the switch (I tried, factory reset etc..but whenever switch is added back to Nebula it always get PLUS license back instead of PRO one).
Haven't found a way how this can be done to simply replace device with existing license by a new higher tier license.
Any recommendation? Hope this is not by design that license cannot be updated/changed in Nebula.
Thank you
Martin
Thank you
Martin
Hi @MartinCZ,
Thanks for asking.
The plus org can be upgraded to Pro org by request now.
Could you help to enable Zyxel support for me to check and provide the org name with me?
Please go to Help Center > Support Request > Zyxel support access to enable and save.
I will help to start the upgrade process.Zyxel Melen0 -
Hi @MartinCZ,
It's been a while did not receive your feedback.
Could you share the below request information for me to help upgrade?
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 203 Nebula Ideas
- 6.3K Security
- 520 USG FLEX H Series
- 329 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.4K FAQ
- 98 Security Highlight
