Beacon Interval setting Zyxel NWA50AX
Idaho8
Idaho8 Posts: 3 image  Freshman Member
edited November 2023 in Nebula
I just bought an Zyxel NWA50AX, configured it with Nebula.
Isn't it possible to change the Beacon Interval in the settings? The manual says so but I can't find such a setting …
Would be very annoying, I bought this AP because I saw in the manual that the max. Beacon Interval can be set to 1000ms. (most APs only have 100ms or 300ms)
Thanks!
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    edited March 2023 Answer ✓
    Hi @Idaho8
    Currently, the Beacon Interval setting is only available on Standalone and AP Controller mode, but Nebula Control Center.
    However, you can use Remote Access to configure the Beacon Interval function via CLI by following the steps on this FAQ.
    Router> enable
    Router# configure terminal
    Router(config)# wlan-radio-profile RADIO_SETTING_TYPE_5
    Router(config-wlan-radio RADIO_SETTING_TYPE_5)# beacon-interval 1000
    Router(config-wlan-radio RADIO_SETTING_TYPE_5)# exit
    Reminder: It's important to note that if the Beacon Interval setting is configured through the CLI for a specific radio, it will be overridden and set back to the default value of 100 once other settings on that radio profile are configured through the Nebula. In this case, if you need to configure other settings for that radio profile through the Nebula, you will need to re-configure the Beacon Interval setting using the CLI again after the other settings are applied.
    In case that you would like to transfer management mode into Standalone mode, here are the steps:
    1. Remove the device from Organization on Nebula at Organization-wide > License & inventory > Devices tab > Actions button > Choose Remove from organization image.png
    2. Reset the device to its default settings by pressing the reboot button.
    3. Access the device management IP address (192.168.1.2) with a default password.
    4. Beacon Interval settings is located at Configuration > Object > AP Profile > Show Advanced Settings > Beacon Interval  AP Standalone.png
    Best Regards,
    Nami
    Nami
  • Zyxel_Nami
    Hi @Idaho8
    Router> enable
    Best Regards,
    Nami
    Nami
Nebula Tips & Tricks
