error secumanager
Get CNM-ID fail, with error=1,msg=Cannot find SecuManager
Looks like you will need direct dialogue with the Zyxel support team. This is the only relevant lead I could find on short notice:
Since your initial post is so short and has no details regarding device model, firmware version etc., I recommend checking whether your configuration is empty (no SecuManager present in config).
SecuManager is a licensed service that can work in a closed (no internet) network environment. It also requires an additional PC to run the SecuManager OS for controlling firewalls. If there is no SecuManager server working in your network before, you could disable the function to stop the error log from appearing.
However, if you would like to centralize the management of your firewalls, you may consider registering your firewall through Nebula . This will allow you to manage your firewall remotely through the cloud without needing to set up additional SecuManager server.
You may have a check steps to setup your devices as Nebula managed mode.0 -
To stop the SecuManager service from your firewall, you can go to Configuration > Mgmt. & Analytics > SecuManager page and uncheck it in the general settings.
Or, you can log in to your firewall via SSH or terminal connection and restoring the SecuManager settings back to default will stop related error logs from displaying again.
Here are the commands to run in CLI:
Router> configure terminal
Router(config)# no cnm-agent auto-get-acs activate
Router(config)# no cnm-agent activate
Router(config)# write0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
