Zyxel NAS326 - fan's speed problem
Gallusik
Gallusik Posts: 1 image  Freshman Member
edited February 2019 in Personal Cloud Storage
Hi
I have a new Zyxel NAS326.
The fan's revolutions make me nervous.
What she wants changes her speed 970 -> 1000 -> 970.
At night it is very audible.
Would not it be better to make corrections to the software that allows you to choose whether the fan should work in silent mode or in normal mode.
Or harmonize the fan speed so that it does not change every 2-3 seconds.
Best regards, Maciej
#NAS_Feb_2019
  • Wiasouda
    Wiasouda Posts: 156 image  Master Member
    no experience this like you, but if the speed up/down very frequently, then you may need to contact your reseller.
  • ukasy
    ukasy Posts: 1
    Anyone resolved this problem?
    I have similar problem but fan speed goes like 1000rpm → 1016rpm → 1000rpm
    2 seconds of one sped than for like 1 second another speed at this cycle this all the time and that sound is quiet but annoying. Replacing fan whould help?
