Nebula event log not working anymore
Hi support
Since around one week I cant see any entries in the event-logs.
steps to reproduce:
click on a client e.g MacBook-Pro
click history, event-log
no details appear in the event-log page. it can be reproduced with any client in the network. when I click on an AP and then history - event log it shows entries.
could you please have a look at my site, the org is called Graf, the site Dietikon. I sent an invitation via the Nebula-GUI. I activated a trial of Nebula Pro which expired around 2 weeks ago, maybe this is the reason why this happened.
rebooting the APs several times didnt help.
all the best
Andrew
Hi Wookie,
We found the same the symptom as you shared, and it should be a display problem, so we’ll fix it and tell you when it is done.
In case, you’d like to check the event log of specific client, please directly go to Access point > Monitor > Event log > and then input the client MAC into Keyword box > click Search as a workaround before we fix problem.
Zyxel_Judy
Hi Judy
many thanks for the quick reply, will do it according your suggestion until fixed.
Hi Judy
do you already have news/timeline when the error will be fixed?
Hi there,
As the schedule, the issue'll be fixed on March 7, 2023.
Thank you for your patience!
Zyxel_Judy
Hi there,
We fixed the issue already. Please help to confirm that.
Thank for your patience!
Zyxel_Judy
Hi Judy
many thanks, I can confirm that the issue is fixed.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
