Nebula bandwidth utilization graph unreliable
Dylan96
Dylan96 Posts: 35 image  Freshman Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
I noticed that both in the desktop website and the mobile app the network utilization graph is just wrong.
there's no way i never exceeded 4mbps in download on a 100mbps line… what's going on here?
This screenshot is from a usg flex 100, but i noticed a similar behavior on many atps we manage…
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,153 image  Zyxel Employee
    Hi @Dylan96,
    Thanks for asking and sharing your network's bandwidth with us.
    This is the diagram of the network usage in the last 24 hours, which means it is not the current utilization. And we can find there's no full loading in this network between 3/12 ~ 3/13 from this diagram.
    Furthermore, if you need to check the utilization, please check the WAN Utilization in the site-wide dashboard.
    Zyxel Melen
  • Dylan96
    Good morning @Zyxel_Melen, i know this is not the current utilization. I am sure the network was full loaded sometime in that time range. If i download something at full bandwidth it is NOT recorded in that graph…
  • monkeynia
    monkeynia Posts: 32 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    edited March 2023
    Hi @Dylan96,
    I'm not sure what's the file size of the "download something" at full bandwidth.
    But I recently downloaded a game that is larger than 100 GB and also curious about my usage, so I checked and have the result below:
    Looks like the diagram you have shows your network usage was not that high as you expected.
Nebula Tips & Tricks
