Multi M1 with TV Orange
COURTOIS
COURTOIS Posts: 1 image  Freshman Member
edited March 2023 in Multy WiFi System
All run fine , master & satellit
But i cannot use my TV BOX Orange ( no flux tv )
I have before yhis porblem with Asrock G10 & OpenWrt
as this post
https://forum.openwrt.org/t/asrock-g10-openwrt-problems/146587/31
https://forum.openwrt.org/t/problem-with-orange-tv/136016
IGMPPROXY ???
Solution for me: build a OpenWrt firmware & flash but i cannot because i have not console login/password
Can you help me ?
  • Zyxel_Kay
    Hi @COURTOIS
    The Multy M1 does support the IGMP proxy function. To better understand the issue, could you please share with us your network topology? Additionally, you may try setting your Multy M1 to bridge mode to see if this resolves the issue.
    Due to the security concern, the SSH Console on the Multy M1 is disabled. Therefore, it is not possible to configure the settings through console login/password. User can only access the Multy M1's setting through the Web GUI and Multy APP.
    Kay
    Kay
