NAS542 lost RAID5 after repair
13»
  • Mijzelf
    Mijzelf Posts: 2,984 image  Guru Member
    What's wrong?
    Don't know. Invisible typo somewhere, I guess. Does
    ls /tmp/
    show the file?
    The /tmp directory is on a ramdrive, so it's content won't survive a reboot.
  • indiana1938
    indiana1938 Posts: 13
    edited March 2023
    That's it, copied again and started process.
    ddrescue informed me to add "—force" to the command line, so I added it and process is running now.
    When copy process is done, what will be the next steps?
    • Removing currend disk from slot 1, putting disk from slot 2 into slot one
    • Replacing disks back into slot 3 and 4
    • Putting one of the new disks into slot 2
    • Restart repair process on NAS via web interface
    Correct?
    Btw., the process will take some more time I guess. ;-)
  • Mijzelf
    Correct?
    Nope. The procedure is
    • move new disk 1 to slot 1, and add new disk 2 and old disk 3 and 4.
    • Check if the 'disk name'/'Device Role' mapping is the same as in this post. That is expected.
    • Re-create the degraded array with 'mdadm —create' like you did before.
    • Reboot
    It's not running at 80MB/sec, as I expected. Instead it's 'just' 50MB/sec. But the 'current rate' is lower. Maybe that disk has more problems than I expected from your problem description. On your screen shot it has 3 read errors in the first 66GB, while I was hoping for 1 on the whole disk.
    BTW, it seems the 'current rate' is used for expected remaining time. At 50MB/sec it should be 11 hours, at 26MB/sec it's 21 hours.
  • I completed the process and …. tadaaaa!
    All data are still present and seved to a separate disk.🤗🤩
    Thank you so much for your kind support and patience on a noob like me. 😉
    Will send you a separate message later.
