4g or 4g+
Fasty
Fasty Posts: 11
edited January 2024 in Mobile Broadband
I have a nr7101 and sometimes it is connected to a 4g and sometiems 4g+. With 4g+ i get download upp to 100mb/s. With 4g I get about 30 mb/s.
I have everything set to "auto". How do I get the info which is the 4g+ band so I can lock it to that?
«13
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Try "System monitor/Cellular wan status, set to 5 secs, scroll down and do speeedtests. Take a screenshot and put it up here.
  • Fasty
    Fasty Posts: 11
    Thank you. Here it is. :)
  • SELBERG
    Do speedtests before you take a
  • Fasty
    Fasty Posts: 11
    Do I need the Zyxel Air app to do the speedtest or can i do it through my webbrowser?
  • SELBERG
    Webbrowser
  • Fasty
    Fasty Posts: 11
    thank you. Do I do the speedtest through the admin-portal?
  • SELBERG
    No
  • Fasty
    Fasty Posts: 11
    You mean I should change to different bands and then do speedtests from my webbrowser?
  • SELBERG
    No do speedtests and take a screenshot like you did earlier. Do at least 3 speedtests.
  • Fasty
    Fasty Posts: 11
    Ok, but how will that help? Now I am connected to the 4g band. I want to connect to the faster 4g+ band and lock it.
