4g or 4g+
I have a nr7101 and sometimes it is connected to a 4g and sometiems 4g+. With 4g+ i get download upp to 100mb/s. With 4g I get about 30 mb/s.
I have everything set to "auto". How do I get the info which is the 4g+ band so I can lock it to that?
Try "System monitor/Cellular wan status, set to 5 secs, scroll down and do speeedtests. Take a screenshot and put it up here.
Thank you. Here it is. :)
Do speedtests before you take a
Do I need the Zyxel Air app to do the speedtest or can i do it through my webbrowser?
Webbrowser
thank you. Do I do the speedtest through the admin-portal?
No
You mean I should change to different bands and then do speedtests from my webbrowser?
No do speedtests and take a screenshot like you did earlier. Do at least 3 speedtests.
Ok, but how will that help? Now I am connected to the 4g band. I want to connect to the faster 4g+ band and lock it.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
