Any firmware updates for Armor G5
1235»
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,405 image  Zyxel Employee
    Hi @dursun
    The Armor G1 device does not support VLAN tagging.
    Thanks for your valuable feedback.
    We appreciate your suggestion and will consider this feature in future products.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited March 2023
    There is a release note for V1.00(ABSK.8)C0 from November (August) 2022 at https://www.zyxel.com/uk/en-gb/support/download?model=armor-g5-nbg7815 , see below.
    The installation using the Wizard should check for the latest firmware.
    @Zyxel_Jerry Is the bin file available for the latest firmware, so that it can be updated by users?
    - the user guide suggests that it should be downloadable from somewhere…
    Kind regards,
    Tony
  • Zyxel_Jerry
    Hi @tonygibbs16
    Thanks for feedback.
    When doing installation and run the wizard, the device will check if there is a new firmware available, if there is no internet at the time, the device cannot check it.
    It seems that is documentation error, on the Chapter 13.6, the firmware is not able to download on the www.zyxel.com, we will modify the document.
  • bimbi
    bimbi Posts: 2
    Where can I find the last Firmware (08) for Armor G5? Link from the side "discontinued hardware" is dead :(
  • Zyxel_Jerry
    Hi @bimbi
    The Armor G5 is using a cloud upgrade.
    You can go to Overview and click the upgrade button if you are not in the latest version.
