Zyxel ATP500 ipsec: no inbound packets
Of course. Create a rule from the WAN interface to Zywall. Source is the WAN IP of the remote end of the tunnel and destination is any. Service is any and Action is allow.
i have sed the same rule but nothing happens. are there other routing/firewall rules should be added?
thank you
For me, this was the solution at the time. But maybe you have a different problem.
Hi @Davidcloude2023 ,
Please kindly check you have rule that "From:WAN to Zywall service: UDP500 and UDP4500"
Please feel free to contact me if the solution not work for you.
Thank you
thank you it worked, i have a question is it possible alsaw to use my laptop to connect to the office from anywhere witha VPN connection like PPTP? i know this can be done with RRAS on Windows server but doing this on USG 100 that is connect IPsec site to site to ATP200 is possible or not?
thank you
I'm glad that your issue has been resolved.
For security concern. Zyxel firewall doesn't support PPTP. But you can use L2TP over IPsec as an alternative.
Please kindly find the FAQ.
Thank you
- 395 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 83 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 415 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
