4g or 4g+
It shows your possible bands but if sinr is 0 you cant use them.
thank you. on which webpage do I do the test where I can see all the different bands?
PCI-Scan @ LTE…..
thnak you. When I do the PCI-scan it doesnt give any results. I have the latest firmware.
I get now abouyt 30m a second and that is ok for me. How many bands can the 7101 be connected to the same time?
5 @ 4G and 4 - 6 @ 5G NSA.
Think all Zyxel 5G router u can't get cell locking in UK for some reason.
Hi. You can Cell Lock 4G / LTE in the UK. I've used it on both the NR5101 and NR7101.
@Fasty your signal quality is really poor and looks like you're on the edge of cell reception hence why it can't maintain 4G+ and drops down to 4G. I'd try and move the Router whilst using the Zyxel Air app and monitor for signal improvements. Move the Router in small stages as it takes a minute or two to reflect in the app. You want to ideally get an RSRP more in the -100 area (give or take) to start to see an improvement. So you need to gain 13dBm. Locking the band isn't going to help here, it is a signal strength problem at the moment.
Yes if signal is strong enough otherwise no.
Does this app support model 7460? Can't connect it in any way, even manually with trying every port
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 77 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
