eits2.zyxel.com has refused the connection
RasnoDigl
RasnoDigl Posts: 16 image  Freshman Member
Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Network Administrator - Nebula First Comment Seventh Anniversary
Good evening, I wanted to know if there are problems with opening tickets in the ncc dashboard in the help center; I can't open the ticket and it says: eits2.zyxel.com has refused the connection. What should I do? Thank you. Andrew
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,043 image  Zyxel Employee
    Hi @RasnoDigl,
    Just like we discussed on the Nebula Live Chat, I will start the investigation for this.
    Additionally, I will also update the result here.
    Zyxel Melen
  • Zyxel_Melen
    edited March 2023
    Hi @RasnoDigl,
    This problem has been fixed.
    And just like your update on the Live Chat, it is working now.
    Zyxel Melen
Nebula Tips & Tricks
