ZON utility found my switch but I can get to the IP address
eliljey
eliljey Posts: 2 image  Freshman Member
edited March 2023 in Switch
I just got a XGS1210-12 switch that I'm using to build a small, isolated lab network off of my PC. The network connection goes through a Benfei USB-C to Ethernet adapter.
The ZON utility came up and found it right away, but I can't open it in a web browser (launched from the utility or doing it manually) or ping it. It's currently using DHCP and giving me an IP of 192.168.1.3 but I've tried a static IP as well.
Any ideas why the utility can talk to the switch but I can't get to it any other way?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    Hi @eliljey,
    Do you mean you cannot access or ping your switch?
    This is more likely because your PC does not have an IP address, the IP address is using a different subnet with the switch, or there has an IP conflict. Please check your PC's IP address first.
    The ZON Utility uses Layer 2 protocol to scan the switch. Therefore, you can get the device information within the above scenario.
    Zyxel Melen
  • eliljey
    I had to change the IP addr of my USB network adapter and switch so they all played together and it works. Thanks for the tip!
