lost password
Hi @Ajay
You can enter the device Web-GUI > Maintenance > Configuration File > Configuration and download the lastgood.conf or startup-config-back.conf that you want to download. Thanks.
https://support.zyxel.eu/hc/en-us/articles/360012744371-What-can-I-do-if-I-forgot-my-USG-FLEX-ATP-VPN-password-or-cannot-access-it-anymore
hi Team.,
Can you please advice how to get access to stage 4 so l can change the backup old startup-config.conf to “startup-config-back.conf” ?
got the far, but password never changed
Press any key to enter debug mode within 3 seconds.
Enter Debug ModeUSG60> atkz b
OK
USG60> atgo
Booting...
Start to check file system...
/dev/mmcblk0p9: 502/30720 files (2.2% non-contiguous), 104322/122880 blocks
/dev/mmcblk0p10: 239/131072 files (7.5% non-contiguous), 19722/262144 blocks
Done
Kernel Version: V3.10.87 | 2021-08-09 21:14:39
ZLD Version: V4.65(AAKY.1) | 2021-08-09 21:54:20INIT: version 2.86 booting
Initializing Debug Account Authentication Seed (DAAS)... done.
Setting the System Clock using the Hardware Clock as reference...System Clock set. Local time: Mon Apr 3 07:25:10 UTC 2023INIT: Entering runlevel: 3
Insmod ZYKLOG Module. Starting zylog daemon: zylogd zylog starts.
Starting syslog-ng secu-reporter.
Starting ZLD Wrapper Daemon....
Starting uam daemon.
Starting myzyxel daemon.
Starting periodic command scheduler: cron.
Start ZyWALL system daemon....
Starting link_updown daemon.
Check signature package
Check av signature package
ADP version 3.12 loaded
Cloud Query Daemon Start!
Got LINK_CHANGE
Port [1] Copper is up --> Group [1] is up
..........Applying system configuration file, please wait...
Got LINK_CHANGE
Port [1] Copper is down --> Group [1] is down
..............................ZyWALL system is configured successfully with startup-config.confGot LINK_CHANGE
Port [3] Copper is up --> Group [3] is upGot LINK_CHANGE
Port [1] Copper is up --> Group [1] is upWelcome to USG60
Username: admin
Hi @Ajay
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
