Zyxel USG Flex 100 no connection to wan and lan
BLS_Philippines
BLS_Philippines Posts: 10 image  Freshman Member
Kindly help
«1
    PeterUK Posts: 4,448 image  Guru Member
    edited April 2023
    So this a new setup? Not much info to go on
    Is PWR and SYS light on?
    Does PC connected to USG get a IP in the 192.168.1.xx can you log in to the USG?
  • BLS_Philippines
    So this a new setup? No it is not a new setup. Last month the device just not working.
    Is PWR and SYS light on? Yes the PWR and SYS lights are on.
    Does PC connected to USG get a IP in the 192.168.1.xx can you log in to the USG? Even if I am connected to the device I am not geting any network response. I cannot log in to the USG not network connection .
    You might have to reset and reload a backup config
  • BLS_Philippines
    How will I do that?
    I do not have a backup config.
  • BLS_Philippines
    I tried hard reset by pressing the reset button for 15 seconds but nothing happens.
  • Fred_77
    Fred_77 Posts: 147 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    HI @BLS_Philippines
    maybe PWR light is red? That means power failure (replace the power adapter)
  • BLS_Philippines
    No the power is not red both PWR and SYS have green lights.
  • BLS_Philippines
    If I turn on the device there will be a one time green light blink on WAN and LAN then nothing even if I connect to WAN and LAN port.
    Are you pressing the reset in as the USG is on?
  • Fred_77
    Could you connect via console cable and share what you see when usg boots up?
