Multy M1 vs Multy Plus?
MultyONR
MultyONR Posts: 3
image  Freshman Member
I was wondering if any of the zyxel techs could answer this question:
Is the Multy M1 less capable/powerful than the Multy Plus system in terms of being overpowered by other Wi-Fi networks?
I have the Multy Plus and am considering replacing it with the M1, but looking through the Multy M1 user guide under "Get to Know Your Multy WiFi System" the M1 seems to be significantly less featured in the comparison charts and this has me wondering which is better...? Thanks in advance
  • hinagan602
    hinagan602 Posts: 1
    edited March 2023
    Multy M1 (WSM20), Multy Plus (WSQ60), Multy U (WSR30), and Multy X (WSQ50) are all independent systems, only the same models can connect. This means that Multy X can not be combined with a Multy M1, Multy U, and/or Multy Plus.
  • MultyONR
    MultyONR Posts: 3
    https://community.zyxel.com/en/discussion/comment/49836#Comment_49836
    Hi, you aren't a zyxel tech, nor did you answer my question so please Do Not respond any further. Thanks.
  • Zyxel_Nami
    Zyxel_Nami Posts: 659
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    image  Zyxel Employee
    Hello @MultyONR
    Thanks for your interested in our Multy products.
    Regarding compatibility when working with another router/modem, both the Multy Plus and Multy M1 can be used as a standalone Wi-Fi system or as an extension to an existing router/modem. However, to establish a Mesh network, please kindly note to use the same model of Multy device. A Multy M1 extender cannot be used to build a Mesh network with a Multy Plus router.
    If you are considering replacing your Multy Plus with the Multy M1, it is important to consider your specific needs and your home/office structure. The Multy M1 may be a more affordable option for upgrading to WiFi 6, but it may not provide the same level of coverage as the Multy Plus due to differences in hardware specifications.
    If you have any further question, please don't hesitate to contact us.
    Nami
    Nami
  • MultyONR
    MultyONR Posts: 3
    https://community.zyxel.com/en/discussion/comment/49962#Comment_49962
    I see...well is there a more updated version of the multy plus system or a similar alternative? Thanks.
  • Zyxel_Nami
    edited April 2023
    Hello @MultyONR
    In terms of a viable alternative, while there are still not migrated models from the Multy Plus, the Multy M1 can still be considered as an alternative, especially if you require faster speeds and better performance with WiFi 6.
    Alternatively, to help us provide a more personalized recommendation, please let us know more about your specific needs, such as the size and structure of your home/office, the number of end devices, and any other reasons for seeking an updated version of the Multy Plus.
    We hope this information is helpful in your decision-making process. If you have any further questions or concerns, please don't hesitate to reach out to us for assistance.
    Best Regards,
    Nami
    Nami
