Add device Nebula
When i try to add a device (Zyxel NR5101) in Nebula with correct Mac adress ans serial number)
i receive : Cannot find device.
Hi there,
Only Nebula supported version can be managed by Nebula, and it is labeled on the sticker with “Nebula”. You can refer to Nebula supported version sticker photo.
In case, there is Nebula label on your NR5101, however, you still get the the message as “Cannot find device”, please provide the MAC address and series number via private message by clicking my account > Message. We'll help to check and register to Nebula if your device is a Nebula supported version.
Zyxel_Judy
Hi there,
Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
