How to empty the recycle bin?
Hello all,
Can I see the recycle bin somewhere on a NAS326 and also empty it? I have not found anything so far.
Marsi as Fabi
You can see recycle bin option on both creating folder and edited folder.
The deleted files will be moved to the "Recycle" folder if the "Recycle Bin" function is enabled in the Share
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=011004&lang=EN0
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=011004&lang=EN0 -
Thank you very much. Even though the link no longer works, your answer helped me a lot! Perfect!
Here is the working one
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
