What would cause a local URL to be redirected to the NSG100 Firewall.
I have a customer that when they type in a local URL they get redirected to the NSG100 firewall. I personally have had this problem, but I would complete a /release, /flushdns and /renew from the command prompt. Unfortunately this is not recommended for my customer as their server has a static ip address. Your recommendation is greatly appreciated.
Les Hochmeister
Hi @lhoch,
Welcome to the Zyxel community!
Is this problem occurring in LAN or WAN? What's the local URL? What website does the customer expect to see? Could you PM me to check?
Also, could you help to enable Zyxel support so I can check the configuration? Please go to Help Center > Support Request > Zyxel support access to enable and save. Don't forget to tell me the organization's name.
Zyxel Melen0 -
I hate to sound dumb, but I have never PM'd on this site. Assistance please.
Hi @lhoch,
May I know if the specific IP is a DNS server? And what's the client's DNS server setting?
After checking the configuration, I found the URLs have been set as address records and domain zone forwarders.
If you use NSG as the client's DNS server, you could remove the domain zone forwarders. It is because the NSG will provide the specific IP to the clients due to the address records.
This problem might be because the destination device of the domain zone forwarder replies NSG's IP address which causes the client to be redirected to the NSG100.
Zyxel Melen0 -
-May I know if the specific IP is a DNS server? And what's the client's DNS server setting? —RESPONSE: The DNS Server (192.168.1.22) is the same machine hosting the gis.oxfordwater.com website.
The clients DNS is set to:Primary: 192.168.1.22
Secondary: 8.8.8.8
Additional Secondary: 8.8.4.4
-After checking the configuration, I found the URLs have been set as address records and domain zone forwarders.
-If you use NSG as the client's DNS server, you could remove the domain zone forwarders. It is because the NSG will provide the specific IP to the clients due to the address records.
—RESPONSE: The NSG is not the DNS, it is just the Gateway.
-This problem might be because the destination device of the domain zone forwarder replies NSG's IP address which causes the client to be redirected to the NSG100.
—RESPONSE: I changed the domain zone forwarder on the DNS Server from the NSG100 to a different server along with 8.8.8.8 and 8.8.4.4. Could this work??
Hi @lhoch,
Based on the current information, it seems like the DNS server has the address record "gis.oxfordwater.com" with NSG's IP address.
Since 192.168.1.22 is the DNS server and the clients use it as the primary DNS, I recommend setting the address record with the correct IP address on the DNS server rather than NSG. This is because the DNS query won't be forwarded to NSG.
However, if your scenario is that the NSG will help the DNS server to reply to the DNS request, I recommend setting the domain zone forwarder on the DNS server and setting the address record on NSG.
Zyxel Melen0
- 588 USG FLEX H Series
- 477 News and Release
